Bitte Tips zur Optimierung
Beitragvon HeroOne » Do 15. Okt 2009, 23:09
Hallo an alle,
ich habe die Alice Fun Flat. Wenn ich über das Modem Interface auf meine DSL Verbindung klicke, kann ich dort eine Downloadgeschwindigkeit von knapp über 10.000 kB/s sehen... mache ich speedtest oder lade ich etwas aus dem netz, komme ich nur auf Werte zwischen 6000 und 8000 kB/s oder aber ca. 1 MB/s.
Ich habe mit einem ähnlichen Tool wie DMT mein Modem ausgelesen:
dann war ich auf der Seite SpeedGuide.net und habe diese Werte erhalten:
TCP options string = 020405ac0103030201010402
MTU = 1492
MTU is optimized for PPoE DSL broadband. If not, consider raising MTU to 1500 for optimal throughput.
MSS = 1452
MSS is optimized for PPPoE DSL broadband. If not, consider raising your MTU value.
Default TCP Receive Window (RWIN) = 66792
RWIN Scaling (RFC1323) = 2 bits (scale factor: 2^2=4)
Unscaled TCP Receive Window = 16698
In Windows 7, unless "TCP/IP Auto-Tuning" is disabled, only the Current TCP Window is displayed. Use the SG Vista TCP/IP patch instead of the TCP Optimizer for automatic tweaking.
RWIN is not fully optimized (even though it is a comparatively large number). The unscaled RWIN value is lower than it should be. Also, RWIN being close to and above 65535 does not justify the header overhead of enabling TCP 1323 Options. You might want to use one of the recommended RWIN values below.
RWIN is a multiple of MSS
Other RWIN values that might work well with your current MTU/MSS:
63888 (up to 2 Mbit lines, depending on latency. MSS * 44)
127776 (1-5 Mbit lines, depending on latency. MSS * 44 * 2)
255552 (2-14 Mbit lines, depending on latency. MSS * 44 * 2^2)
511104 (8-30 Mbit lines, depending on latency. MSS * 44 * 2^3)
1022208 (25-60 Mbit lines depending on latency. MSS * 44 * 2^4)
bandwidth * delay product (Note this is not a speed test):
Your TCP Window limits you to: 2672 kbps (334 KBytes/s) @ 200ms
Your TCP Window limits you to: 1069 kbps (134 KBytes/s) @ 500ms
MTU Discovery (RFC1191) = ON
Time to live left = 45 hops
TTL value is ok.
Timestamps (RFC1323) = OFF
Selective Acknowledgements (RFC2018) = ON
IP type of service field (RFC1349) = 00000000 (0)
bzw, diese hier im zweiten Fenster:
Tested on: 10.15.2009 16:53
IP address: 80.171.xx.xxx
Client OS: Windows 7
MSS: 1452
MTU: 1492
TCP Window: 66792 (multiple of MSS)
RWIN Scaling: 2 bits (2^2=4)
Unscaled RWIN : 16698
BDP limit (200ms): 2672kbps (334KBytes/s)
BDP limit (500ms): 1069kbps (134KBytes/s)
MTU Discovery: ON
TTL: 45
Timestamps: OFF
SACKs: ON
IP ToS: 00000000 (0)
Habt Ihr irgendwelche Tips oder Anleitungen (für meinen speziellen Fall), was ich machen kann, um meine Geschwindigkeit zu erhöhen????
Vielen Dank im Vorraus!
H.O.
HeroOne
Re: Bitte Tips zur Optimierung
Beitragvon B13 » Do 15. Okt 2009, 23:44
Ist der PC via WLAN mit dem Router verbunden?
B13
Beitragvon HeroOne » Do 15. Okt 2009, 23:46
nein fest per Lan-Kabel.
HeroOne
Beitragvon B13 » Do 15. Okt 2009, 23:49
Jetzt hätte ich Dir gerne zum kleinen, aber feinen Tool 'DFÜ-Speed' geraten - weiß aber nicht, ob das mit Windows 7 arbeitet. Versuch macht klug?
B13
Beitragvon HeroOne » Do 15. Okt 2009, 23:56
funktioniert... kannst du mir sagen was ich wie einstellen muss?
siehe Bild:
HeroOne
Beitragvon B13 » Fr 16. Okt 2009, 00:43
Einfach unten, rechts auf "DSL Optim." klicken und dann per Klick auf "OK" bestätigen. Dann ein Neustart von Windows und gut (so möchte man hoffen).
B13
Beitragvon vector2a » Fr 16. Okt 2009, 21:21
Win7 hat wie Vista einen neuen Netzwerk-Stack. Optimierungsprogramme helfen da nicht, da sich der Stack bei jedem Boot selbst "optimiert".
Beitragvon HeroOne » Mo 19. Okt 2009, 13:09
aha ok - danke.
Ich habe Alice mal eine Mail geschrieben mit den Daten und sie haben gesagt, dass bei einer Überprüfung festgestellt wurde, dass das Modem nicht die volle Bandbreite bekommt. Sie haben geschrieben, dass sie einen Portreset gemacht haben... habe jetzt im Modem-Interface einen max. Download von 10.700 festgestellt gestern. Im Download habe ich trotzdem max. 1 mb/s keine Ahnung, ob das jetzt was gebracht haben soll... naja danke für die tips @ all.
ich hoffe mal weiter auf Alice VDSL ;-)
HeroOne
