English Bitte?
English Bitte?
Beitragvon scottsdesk » Mo 5. Aug 2013, 03:45
Installing DSL with Alice IAD WLAN 3232, I should have to have a password normally right? Everything is connecting but its kind of strange to only need my telephone number as the username and not a password. Using wifi is that not insecure, to not need a password on my account? I have attempted to translate in German but it prolly makes no sense.
Installieren DSL mit Alice IAD WLAN 3232, sollte ich ein Passwort normalerweise Recht haben? Alles verbindet aber seine Art von seltsamen, nur brauche meine Telefonnummer als Benutzername und kein Passwort. Mit Wi-Fi ist, dass nicht unsicher, um nicht brauchen eine Passwort auf meinem Konto?
scottsdesk
Re: English Bitte?
Beitragvon Undertaker » Mo 5. Aug 2013, 04:21
1. To install the Alice IAD 3232 no password is required, but you can enter in the web interface of the IAD a personal password.
2. To establish the Internet connection you use the credentials of Alice/o2.
3. The security key for the wireless network you can find on the bottom of the IAD
4. To unlock the phone function you get a PIN from Alice/o2
one post is enough so I deleted your identical twin post
* Google translator can be helpful :wink:
