DSL-modem turbolink IAD and its connection
Beitragvon sgmf » Do 18. Nov 2010, 16:09
Dear All,
First of all, I'm sorry that I'm writing to you in English but for me it is difficult to explain my problem in German.
I'm pretty sure, that the answer on my question I could find here, but it is on German ((
The story is the following.
I'm interested in Alice product mainly because of calling in Belarus (Whiterussia), with "Europe Talk and more option".
Therefore, for me is important to use Alice-Telefon.
So, Few days ago, I got an Alice internet connection and got a Sphairon-Turbolink DSL-modem
http://www.alice-wiki.de/Sphairon_Turbolink_IAD
The problem is that,
I cannot connect my IP-TV box and sony playstation 3 to this modem.
I'm sure that I do everything properly with "pppoe" connection and correct alice name (Phone number@alice-dsl.de) and password (ddmmyyyy).
However, I'm able to connect to my notebook with a cable, but every time when I switch on the laptop I should make connection in "Network connection".
Is there some option, how to make this connection "always online" ?
So, in order to avoid problems with the modem, I decided to by a router either Fritz box (for example) or W-lan box from Alice.
And the question is:
1. If I take the Router from Alice, how should I connect it, that my telephone option "Europe Talk and More" work properly?
Is it like that: Turbolink-Modem --> Router ---> PC and telephone connected to the Turbolink-Modem or
I can connect Router directly to the Phone Plug?
2. If I take Fritz box, I know, that I should connect it like Turbolink-Modem --> Fritz ---> PC!
Will in this case my telephone option "Europe Talk and More" work properly?
Thank you for you help in advance and I hope, I explained all details.
sgmf
Re: DSL-modem turbolink IAD and its connection
Beitragvon Undertaker » Fr 19. Nov 2010, 03:35
sgmf hat geschrieben:First of all, I'm sorry that I'm writing to you in English but for me it is difficult to explain my problem in German.
Do you know Google translate?
sgmf hat geschrieben:So, Few days ago, I got an Alice internet connection and got a Sphairon-Turbolink DSL-modem
The problem is that, I cannot connect my IP-TV box and sony playstation 3 to this modem.
The Turbolink IAD is only a modem, not a Router. There is only 1 PPPoE connection allowed at the same time.
sgmf hat geschrieben: Is there some option, how to make this connection "always online" ?
Copy your PPPoE-Connection Button from the Desktop in the Autostartfolder or buy a WLAN Router without Modem, then it works.
sgmf hat geschrieben:1. If I take the Router from Alice, how should I connect it, that my telephone option "Europe Talk and More" work properly?
Is it like that: Turbolink-Modem --> Router ---> PC and telephone connected to the Turbolink-Modem or I can connect Router directly to the Phone Plug?
No the Router from Alice is an exchange of Alice. You get a new IAD integrated with a Router and send back the "old" IAD.
New IAD with Router --> PC, IP-TV-Box and Sony Playstation and Telephone connected to the Telephone connection port on the new IAD.
sgmf hat geschrieben:2. If I take Fritz box, I know, that I should connect it like Turbolink-Modem --> Fritz ---> PC!
Yes that is correctly.
A simple and favorable way is to buy your own Router without a Modem inside and attach it to the Turbolink IAD. For example, D-Link 524, 624, DIR 300, DIR 615 or TP-Link and Linksys Routers without Modem. Look at ebay.
Beitragvon sgmf » Fr 19. Nov 2010, 11:02
Vielen Dank für Ihre Hilfe.
Jetzt ist alles klar für mich.
P.S. Naturlich weiß ich "Google Translate" :D
sgmf
Mitglieder in diesem Forum: 0 Mitglieder und 40 Gäste
